  • 1994 - 1995 Specific Tech
ac compressor not engaging
  • Thread starter Thread starter icemetalstang
  • Start date Start date Apr 10, 2009
First Prev 2 of 2
9
.95stang.
11
south texas
Jul 14, 2010
#21
  • Jul 14, 2010
  • #21
ok but do i disconnect the harness from the ccrm and check the voltage? or do i probe the wires while connected cus there was no voltage present when disconnected in pins 23 or 22
HISSIN50
34
129
Jul 14, 2010
#22
  • Jul 14, 2010
  • #22
It has to be connected.
9
.95stang.
11
south texas
Jul 14, 2010
#23
  • Jul 14, 2010
  • #23
ok. but in what wire should i see voltage on the high pressure switch? im confused. on the dg/o or another one?
9
.95stang.
11
south texas
Jul 14, 2010
#24
  • Jul 14, 2010
  • #24
ok no voltage on dg/o, blk/yell, pnk/yell
HISSIN50
34
129
Jul 14, 2010
#25
  • Jul 14, 2010
  • #25
If you had 12V leaving the LPCS (not just going into it) and your WOT relay testing is correct, there should be an open in the wire between the LPCS and the WOT relay. This is not real likely.
If you disconnect the LPCS (and remove whatever jumper you're using) and unplug the CCRM electrical connector, you can do a continuity test on both ends of the input wire.
9
.95stang.
11
south texas
Jul 15, 2010
#26
  • Jul 15, 2010
  • #26
the lpcs is the one on the accumulator? i found 12v on the wire that is either purple or pink but found no voltage on the high pressure switch. so the power goes from the lpcs to the high pressure switch to the ccrm to the a/c compressor. is that right?
9
.95stang.
11
south texas
Jul 19, 2010
#27
  • Jul 19, 2010
  • #27
what color wire should i check for continuity? and its from the lpcs to the ccrm correct?
HISSIN50
34
129
Jul 19, 2010
#28
  • Jul 19, 2010
  • #28
Going off memory, it's dk grn/or. Yes, it's one wire you're checking (along its run from the LPCS to the CCRM).
HISSIN50
34
129
Jul 19, 2010
#29
  • Jul 19, 2010
  • #29
And did you confirm that Pink/yel does not show continuity to ground?
First Prev 2 of 2
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
F
AC System Leak
  • Fri Guy
  • Sep 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
Fri Guy
F
M
  • mnky99
  • Sep 5, 2025
mnky99
M
