  • 1994 - 1995 Specific Tech
AC Compressor
  • Thread starter Thread starter rlrr
  • Start date Start date Apr 24, 2009
R
rlrr
St. Louis, MO USA
Apr 24, 2009
  • Apr 24, 2009
My AC is not working in my 1994 Mustang GT Convertible. The system is charged.
I only have 10 volts at the compressor when I turn the AC on and I do not hear it click.
How many volts should I have?
Suggestions?
THANKS!
HISSIN50
34
129
Apr 24, 2009
  • Apr 24, 2009
If the compressor doesn't engage, how do you know the system is charged?
Check the LPCS. You should have 12 V into it with the AC turned on, and 12 V leaving it if your system is indeed charged. IF you have 12V egressing, the clutch should engage.
Disconnect the clutch's connector and ohm out the ground. Look for around 5 ohms.
If you have 12V leaving the LPCS and the clutch's wiring is ok, the issue is probably at the WOT relay. I'd have to look at a schematic to see what to check there.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
