AC Delete Kit
yeah, before doing it, make sure you have the belt. lol other wise your car might be down, until you can get one. i bought Marches AC/PS delete kit. BUT, if i want to delete both(which i did) it also deletes the smog pump. i guess they dont want AC/PS/SP delete in the title. it wasnt hard to install, BUT on mine it relocates the tension pulley where the AC was. when i put it on, everything looked fine, but the pulley was slightly out of alignement with the rest of the pulleys. so i just used a couple washers as shims. and it works beautifully.
~Steve
It's not hard to do, I deleted A/C and smog at the same time on mine. Definately have to have a new belt, some disconnect tools, and some hand tools. There's a diagram somewhere on here that shows how to route the belt and so on. Do a thread search. Also, measuring the belt is tricky, I've heard using a string and routing it correctly, then measure it. I made about 4 trips to the part store before getting the correct belt for mine.
here is some pics of the ford delte kit on a 351. the hardest part is taking the time to shim the pump with washers until you can get it to where the belt stays on all the pullies.
my ac delete wasn't that hard. I had the FMS kit and the hardest part was gettign the correct belt. I believe it was the 70.5" one the fit(I have no smog) It was real tight at first but it was the only one that fit.
FordGuy88 said:
What is the easiest way to measure it.
Supposedly you can measure it with a long piece of string, wrapped around the pulleys like the belt. I have tried this several times though, and have had to go to the parts store at least twice, everytime.
Good Luck
