  • SN95 4.6L Mustang Tech
AC HELP!!
  • Thread starter Thread starter Jacob_Royer
  • Start date Start date Jul 14, 2008
Jacob_Royer
142
  • Jul 14, 2008
Anyone have a pic of were the orfice tube is located on these things?? (96 gt)
thanks!
rabidscoobie
616
12
48
College Station,TX
Jul 14, 2008
  • Jul 14, 2008
It should be on one of the metal lines connecting to the accumulator/dryer,cant remember if its the inlet line out output line,I think its in the line on the firewall side.If you dont know what the dryer is,its the can looking thing on the passenger side next to the firewall about the sixe of a coffee can.
Mustang5L5
Mod Dude
Feb 18, 2001
43,363
18,107
224
Massachusetts
Jul 14, 2008
  • Jul 14, 2008
It's the line that runs from the condensor in front of the radiator down the passenger side of the engine bay to the accumulator bottle on the firewall.
Hardtop68
193
Wherever they need me
Jul 14, 2008
  • Jul 14, 2008
The orifice tube is on the liquid line... it is not replaceable unless you modify the liquid line...
Check this thread I posted some info about this matter:
http://forums.stangnet.com/755522-c-compressor-replacement-questions.html
Jacob_Royer
142
  • Jul 15, 2008
Hmmm.. When i bought the car the AC didnt work and i checked it and it was low on freon... I topped it off and i had ice cold ac for a day! next day it didnt work checked the pressure... it was fine! compressor kicks on kicks off kicks on kicks off thats all it does.. tried adding a wee bit more freon and it still did the same thing.. Im thinking... pressure switch or clogged orfice tube?? what is involved with changing the pressure switch on these cars?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 15, 2008
  • Jul 15, 2008
If the orifice tube is pluged you will get abnormal presures..
since the presures are fine I would look at the cycling switch.. but it would not be a bad Idea and seperate the line and check the orifice for debris..
blacksheep-1
322
Jul 15, 2008
  • Jul 15, 2008
I just went through some of this on my father in law's car, excellent call on the replacement piece for the liquid line orifice tube.
BobHyatt
378
  • Jul 15, 2008
You need to hook up a set of guages and look at liquid and suction pressures. If the orifice tube is blocked, suction pressure will be low and pressure line may be high (or not). Also you need to verify that the blend-air door is moving and that it isn't stuck in a partially-open mode where some of the cabin air goes through the heater core making it look like the A/C is not working properly.
If compressor is kicking on and off, it doesn't sound like a plugged orifice tube. Is the drier cold to the touch?
Mike97gt
it doe snot
10,633
Jul 16, 2008
  • Jul 16, 2008
to add to this, is the compressor short cycling? by that I mean cyling off after about a second if it is then most likely you are low on freeon and have a leak.
BTW good call on the blend door I have seen that burn people.
Hardtop68
193
Jul 21, 2008
#10
  • Jul 21, 2008
  • #10
Check the A/C with the engine cold... if the problem is the blend door, the A/C will work OK for a short while until the coolant gets hot...
BobHyatt
378
#11
  • Jul 21, 2008
  • #11
Friend got burned with the blend air door. Bought a Taurus SHO at a used-car lot (bad idea) during the very early spring. Salesman told him "only problem is it needs a new thermostat, it is stuck open and won't produce any heat in the car." Friend bought it, hook, line and sinker. Turns out the blend air motor electronics were bad. Door would just oscillate from hot to cold. Previous owner found the connector behind the glove box and randomly disconnected it until it happened to stop on "cold" where it was left (worked fine for the summer). Needless to say, an expensive repair that had nothing to do with a stuck coolant thermostat.
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
C
Looking for electrical schematic 1986 GT
  • CMT3
  • Sep 21, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 23, 2026
AeroCoupe
