  • 1994 - 1995 Specific Tech
AC questions for a 95 GT
  • Thread starter Thread starter ravenschyld
  • Start date Start date Aug 29, 2008
R
ravenschyld
  • Aug 29, 2008
My 95's AC was running great, then one day it just quit, started blowing warm. There is a good charge, and the compressor is still good. When I checked the switch at the firewall, there is no current running to it. Also, I checked the switch on the compressor clutch itself, and got no current to it either. All of my fuses are good, so now I am stuck...I really dont want to take it to a garage because I really dont want to pay what they want. Any ideas as to where I am losing the connection? Any and all help will be greatly appreciated!!
desertcox05
379
south atlanta
Aug 30, 2008
  • Aug 30, 2008
i know the signal goes through the ccrm. thats the box over the radiator resevior. if you have a wiring diagram and a multi meter you should be able to trace it down
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 30, 2008
  • Aug 30, 2008
to :SNSign:
Check the low pressure sensor on the accumulator. If you know for certain the charge is sufficient, unplug the harness from the sensor and jumper the terminals. If it works, grab a new one from the auto parts store of your choice. It's a pretty common problem on our cars.
HISSIN50
34
129
Aug 30, 2008
  • Aug 30, 2008
Were you being literal? If you have no power to the LPCS (the power signal comes from the HVAC controls), then trace the issue backwards from the LPCS.
Otherwise, I'd put a set of manifold gauges on and quickly do as Matt suggested. Don't run the car long at all with the LPCS jumped.
The power path is from the HVAC controls, to the LPCS, to the CCRM (Common and NC terminals) and then to the clutch. So obviously if you have no power in or out of the LPCS, there will be none at the CCRM (WOT relay) or the clutch.
Good luck.
R
rcracerx
  • Aug 31, 2008
I'm having a similar issue with my 94. The AC system has the correct charge, and I'm trying to locate the fuse for it. Is it in the fuse box under the dash r somewhere else?? Iv'e tryed looking for it but havent been successfull. Sorry about highjacking your thread btw.
HISSIN50
34
129
Aug 31, 2008
  • Aug 31, 2008
Fuse 6 inside the car is for the HVAC controls IIRC.
If you have power going to the LPCS, your controls and fuse are fine. You'd need to diagnose it from the LPCS down to the compressor.
R
rcracerx
  • Aug 31, 2008
is there a link i can follow up on??
F
fkloss
14
  • Sep 1, 2008
Pressure switch could be bad.
I replaced mine couple of years ago.
It will show those type of symptoms.
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
T
Losing Refrigerant rapidly on my 98 Mustang GT
  • TekoSn95
  • Jun 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
TekoSn95
T
