I was responding to the post refering to freeze12 smoking a compressor.
134a is the only refrigerant for car ac that will cause you a problem with the wrong oil.
You can use POE or standard oil in R-12,FR12,Hotshot charged systems with out problems.
So that being said, if you trash a compressor and you are not using 134a then you either overcharged or undercharged the system...that assumes that the system was properly evacuated and the system operates normally(all components function corectly).
Overcharging a system (low superheat) will cause liquid refrigerant to mix with the oil washing the bearings causing bearing failure if you way overcharge a system you could cause the compressor to try to compress liquid(refrigerant/oil) resulting in failure.
If ya don't believe me go buy a can of 134a (12oz.) and add it to a new cars ac system then see how long the compressor lasts.
I understand what you meant, but if the system is working properly a short charge won't hurt the compressor because it has a low pressure "safety" cut-out. An overcharge will take down a compressor given time, but I have seen them freeze up with no internal damage. I also mentioned that I have seen some bad things happen when overfeeding/overcharge is not rectified. SO, on the overcharge we are in agreement.
As for refrigerant/oil combos take a look at this. The first row of samples show what some of this "drop in" stuff will do to mineral oil. Now you know why the Freeze 12 took out the compressor so fast.
Bottom line is this: There is no true drop in replacement for R-12. Even the r414b (hotshot) runs with a short charge. That is not to say it won't work, but if you have ever seen a system with a liquid line sight glass and R-414b it will have bubbles, and that means refrigerant is flashing before the metering device. In a low temp application this is more prevalent, and usually the solution is to adjust the TXV, or change the metering device if it is not adjustable. ICOR international will tell you just to charge the system to 80 percent, but IMHO that is marketing hype. It would be hard to sell their refrigerant as a "drop in" replacement for r-12 if they had to have an asterisk explaining that little fact.
Bottom line: if your looking for a cheap replacement for r-12, Hotshot will work in a car AC. Just keep in mind the link above.
More to the topic, however, is the evap and condenser in the OP's car. If they have not been sealed from the elements since your dad pulled the AC out, I'm not sure I would use them at all. That's just me though.
EDIT: So no one is mislead: The website that I posted the link to regarding the oil Miscibility is owned by Autofrost or R406a. While the samples are real what they fail to mention on that page is that r406a will eventually break down mineral oil and become very discolored. It is recommended that you use a AB( Alkyl Benzene) refrigerant oil with either r406a or r414b, but now we are right back to square one with the r134a issue. So considering the fact that the oils at least should be changed, R134a is the better choice because it is not a blend of refrigerants like the R12 replacements. The blended replacements can frationalize and the different refrigerants will leak at different rates. In the case of Autofrost(r406a), it can leave you with a flammable substance.
There is a reason EVERY major auto manufacturer uses R134a
