Hey all, just wondering if Accel coilpacks will work with my Ford 8mm plug wires. I know with the Screamin' Demon coil packs, you need to get Livewires because the output voltage is too high for stock wires, but is this the case with Accel coils? I only ask because I can get them for $45/ea, but if I need to get new wires too, then its not such a good deal. These are the specs... Thanks!
Accel-
Coil Style: Coil pack
Coil Internal Construction: Epoxy
Maximum Voltage: 42,000 V
Turns Ratio: 85:1
Primary Resistance: 0.500 ohms
Secondary Resistance: 11.6K ohms
Would you recommend just getting stock motorcraft replacements instead?
Accel-
Turns Ratio: 85:1
That's about what they do now. Keeps weight on the box on top of my freezer.
