  • SN95 4.6L Mustang Tech
ACCEL coils
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date Jun 8, 2010
D
Jun 8, 2010
  • Jun 8, 2010
Anyone have experience with them? Good? Bad? Anything?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2010
  • Jun 8, 2010
Do a search.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jun 8, 2010
  • Jun 8, 2010
they are chit....i, unfortunatly, in desperate need had to by them for my car...i myself have had no problems with them yet other then wehn i installed them i had to line the pins up in the connectors correctly to plug them into the harness cause they were all out of whack...
on the other hand, tons of people buy them from where i work..99% of those people have to send 1 or more coil back due to it not working...keep that in mind before you buy them...if you want to go aftermarket, buy either msd(which really isnt much better) or weapon X... weapon X seems to have a great design going on
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jun 8, 2010
  • Jun 8, 2010
meh, i asked around before i bought them and nobody has had any complaints. ive been running them for almost a year and they have been great.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jun 8, 2010
  • Jun 8, 2010
my car felt a little smoother after putting them on but im still a little scared of them lol
theyll look good with your yellow car at least
RedDaemon
3,470
9
108
Atlanta, GA
Jun 8, 2010
  • Jun 8, 2010
ive been using motoblues for 2 years now. sure people hate rpmoutlet but i didnt have issue with them
EDIT: i dont think rpmoutlet sells mine anymore or they renamed them to WeaponX. I know I didnt pay $400 for them thats for sure..
I
ItsStock02
492
Westland, MI
Jun 8, 2010
  • Jun 8, 2010
Ive had mine since christmas and no problems at all.
StangSims39
164
Farmingdale, NY
Jun 8, 2010
  • Jun 8, 2010
i was wondering the same thing with the ACCELS, but some have said unless you have an issue with some current packs that its just a waste...:\ how are the GMS?
2006KJ
128
North West PA
Jun 8, 2010
  • Jun 8, 2010
i've put 3000 hard miles on my accels and they've been perfect.
C
charged2vGT
Pittsburgh, PA
Jun 8, 2010
#10
  • Jun 8, 2010
  • #10
JUNK!!!!! I had bad spark blow out. they are made by mr gasket. never would use or sugest them to anyone!!!
D
Jun 8, 2010
#11
  • Jun 8, 2010
  • #11
Thats the problem I have. Im experiencing the dreaded COP issue that seems to be pretty common on the 4.6 2V's.
I really really dont want to be spend $350+ on coils. The ACCEL's are $190 from Summit
flstang65
1,484
135
94
SE Georgia
Jun 9, 2010
#12
  • Jun 9, 2010
  • #12
I would stick the the stock Ford ones.
StangSims39
164
Farmingdale, NY
Jun 9, 2010
#13
  • Jun 9, 2010
  • #13
I mean i think they are cheaper than getting the OEM COPS, you could just go for them and see how they work, if they dont then chock it up to epxerience, but there seem to be mixed reviews on these, like anything else, some hate and have horrible experience, others think they are the best product in the world, its just going to boil down to your preference, i would check out accels warrentee, make sure that if there is a problem you can get your money back, then just go with stockers, or save up for the msd or GMS cops....
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jun 9, 2010
#14
  • Jun 9, 2010
  • #14
FWIW, ford wants $98 a piece for the OEM motorcraft COP's.... so unless you want to spend $780ish for new cop's, id go with msd or weapon X...who knows, maybe youll even get lucky with the accells
I
ItsStock02
492
Westland, MI
Jun 9, 2010
#15
  • Jun 9, 2010
  • #15
Ive got a set of oem cop's ill sell to anyone whos interested
joshjwc9
1,095
17
39
Palm Harbor, FL
Jun 9, 2010
#16
  • Jun 9, 2010
  • #16
Summit sells their own brand, but for $270ish. I think MSD makes theirs though too.
trinity_gt
3,125
81
99
Canada
Jun 9, 2010
#17
  • Jun 9, 2010
  • #17
I think HV coils would be a waste unless your setup requires them.
The voltage required to ionize the plug gap and to establish an arc is largely a function of the plug gap and electrode condition and of the environment (e.g. mixture ratio, pressure etc) between the electrodes. As compression pressure goes up, so does the voltage requirement, all else being equal. This is typically seen when running, say, a blower. When a spark is "blown out", it's not really "blow out" but rather the problem is that the coil cannot generate the voltage required to establish an arc. This can actually damage the coil because while the HV cannot jump the plug gap, it can damage the insulation within the coil itself. A typical fix on FI engines is to reduce the gap from 0.054 to 0.030 or so to bring the arc-point voltage down. In this situation, a HV coil may be beneficial to allow the running of a larger gap thus exposing more AF mix to the arc and further reducing the chance of misfires and emissions issues (e.g. unburnt HCs).
However, because the voltage requirement is set down in the chamber, the extra capacity to generate HV is wasted on engines with running conditions that don't require it. If 25kV is the arc-point, that's how high the voltage will climb before the discharge occurs. If the factory coil is good to 35kV, running a coil capable of generating 50kV won't give any benefit if the arc-point is only 25kV. The benefit comes from situations where conditions require, say, 40kV and the coil is only good to 35kV...
In addition, coils are transformers and thus have primary and secondary windings. In order to generate that much higher secondary voltage, one can change a few parameters in the design of the coil. Additional secondary windings are the typical way. However, more windings may mean a thinner gauge of wire which is more fragile and which will also have a higher secondary resistance. This may mean increased operating temperatures in the coil (I^2R losses) and perhaps even reduced arc current.
Bottom line, IMHO: If you are normally aspirated and the OE coils are otherwise performing normally, leave them. If you're FI, reduce the gap to the minimum required to prevent misfires and/or consider a quality HV coil to allow an increase in gap again.
M
mr-mike
122
#18
  • Jun 11, 2010
  • #18
I have a 99 & 2 went bad I put on ones from the junkyard then another so I bought a set from e-bay $200 that was about 5 years ago & no problems since.. they said Lightning I dont know if they still sell them they had no writing on then ? but are fine ....seems like lots of the OEM go bad & some dont so yes I would go for a new set & not OEM ....they dont like water so washing engines is a no-no ..... maybe some guys will chime in about the ones you asked about , good luck
Shiroelex
There's nothing worse than aut
728
Westland, MI
Jun 11, 2010
#19
  • Jun 11, 2010
  • #19
I went through two sets of Accels, and will never buy an Accel product again. They are total crap! I had a bad one right out of the box! I just went through hell in a handbasket trying to figure out why my car was running so bad under load, and it ended up being those stupid coils. A million parts later, I replaced the coils with new Motorcrafts and all is well. It runs SO much better. The Accels were great for me for almost a year, then the idle got slightly rough. About a month later, it would REALLY crackle and pop under deceleration. A few weeks after that started, it was just crap.
RedDaemon
3,470
9
108
Atlanta, GA
Jun 11, 2010
#20
  • Jun 11, 2010
  • #20
Good thing i have kept my motorcraft COPs..mine crackles and pops like you stated but its never gotten worse than that. Every once in a while, the misfire will come about...typically on a cool (~65), but humid day
C
99 mustang gt no signal to fire coils
  • Cerana04
  • Oct 4, 2025
SN95 4.6L Mustang Tech Oct 4, 2025
Cerana04
C
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
Mustang I I truck gasket
  • roadsterII
  • Aug 4, 2026
1974 - 1978 Mustang II Talk & Tech Aug 8, 2026
Enzio
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
