Accel Distributor Problem(s)
  • Thread starter Thread starter matm347
  • Start date Start date Apr 9, 2004
M
matm347
2,056
  • Apr 9, 2004
I have had my Accel distributor for about 5k miles. I had one problem where the screws that hold down the hall effect sensor down came loose, luckily I caught it before it caused any damage.
Just last night I was driving home and my car suddenly started running like CRAPOLA, hardly wanting to start and not wanting to go much faster than 40 MPH. All gauges looked OK so I limped the rest of the way home(2 blocks). I pulled the cap of to see if the distributor was the issue(everything else looked OK and even though it ran like butt, it was smooth.) I tried to rotate the rotor and it spun pretty freely, it felt like the distributor gear had gone. So I pulled the distributor out to check the damage and it looked worn, but fine, the pin was fine as well. So I held the gear and rotated the rotor, it turned pretty easily, enough so that any rapid RPM change would cause the rotor to turn out of timing. I'm not sure what has happened at this point as I have not pulled the distributor apart yet.
I was wondering if anyone else has had this issue before, and what was the cause.
Also, this may be a good reason to stay away from Accel distributors, I would have gone MSD but did not realize they had a direct swap distributor.
To me, this is a serious issue, what if the timing had been advanced instead of retarded? What if I was making a pass under boost or gas? This could have melted pistons, bent rods, snapped crank!
M
matm347
2,056
  • Apr 10, 2004
I just took it apart and found that Accel uses a press on fitting with teeth that are supposed to interlock, mine aren’t when fully pressed, but do when pulled up some. I fired off an e-mail to Accel tech support asking about some sort of recall/replacement.
I can customize and modify it to work permanently, but I'll see what Accel says about this.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Resolved Does anybody recognise this distributor gear?
  • x_man586
  • Jun 4, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
x_man586
Distributor choices
  • Stang9050
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Stang9050
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
