SN95 Accelerating On Its Own?
  • Thread starter Thread starter dubbsix
  • Start date Start date Jul 9, 2014
dubbsix
347
Katy,TX
Jul 9, 2014
  • Jul 9, 2014
Whats causing my 94 GT to feel like im pressing the gas pedal when im not? When im driving and I am around the 25-35mph range if i take my food off the gas the car still accelerates.. albeit slowly, but its a noticeable acceleration. What is causing this ?
Thanks for the help!
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jul 9, 2014
  • Jul 9, 2014
Does the car have a high idle or hanging idle? Is the throttle pedal or cable sticking?
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Jul 9, 2014
  • Jul 9, 2014
The gas pedal is no place to put your food.
Reactions: NTO_GUY, 90lxwhite and FastDriver
dubbsix
347
Katy,TX
Jul 9, 2014
  • Jul 9, 2014
the idle is actually smooth and low. I it doesn't run rough it's just when coasting I feel a surge like I'm pressing the gas.
dubbsix
347
Katy,TX
Jul 9, 2014
  • Jul 9, 2014
well the cup holder is too small.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jul 9, 2014
  • Jul 9, 2014
Is this an auto or 5spd?
dubbsix
347
Katy,TX
Jul 9, 2014
  • Jul 9, 2014
Hi
Auto.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jul 9, 2014
  • Jul 9, 2014
I would start by trying to reset the idle and getting it down to where it should be from the factory. Maybe @jrichker can give you the reset procedure and provide a few more things to look at in regards to your high idle. The high idle is likely responsible for what you are describing
dubbsix
347
Katy,TX
Jul 9, 2014
  • Jul 9, 2014
Im sorry, dunno where the "HI" come from. the idle is low/normal around 900rpm's and doesnt seem to idle or run rough even when goosed via throttle bracket.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,241
2,949
224
Vass, NC
Jul 10, 2014
#10
  • Jul 10, 2014
  • #10
Why don't you try gassing the throttle cable from the engine bay at the throttle body and see if the cable is sticking. This is a dangerous situation, if so. I am surprised by the ignorance of the people driving the toyotas and lexuses that ended up dieing because of sticking throttles, but I just bring that up so that you think about how you would handle the situation if it happened to you. It should be easy: manual = push in clutch, put tranny in neutral, steer/brake to a safe stopped place, and THEN kill the engine (the rev limiter should protect the motor). Auto, same procedure after shifting the gear select into neutral.
dubbsix
347
Katy,TX
Jul 10, 2014
#11
  • Jul 10, 2014
  • #11
Checking out the cable is worth a shot. I am thinking about replacing the IAC/TPS with new units to see if they have any impact on the issue. Typically you dont troubleshoot by buying new parts, but I think they are cheap enough and easily removed to test.
Reactions: tamadrummer88
Admin Dude
Jan 4, 1985
43,580
21,743
234
Box behind Walmart
Jul 10, 2014
#12
  • Jul 10, 2014
  • #12
I'd would be disconnecting the throttle cable from the throttle body and checking to see if the throttle body sticks by carefully and slowly opening it and watching it fully close.
Then I'd flat out replace the cable with an OEM quality cable.
If the car idles smooth, doesn't buck, and holds a nice and steady power level at cruise then it's not likely to be the IAC.
The TPS can be checked out by disconnecting it and putting an ohm meter to it. Open and close the throttle body slowly and see if there are inconsistent jumps. Generally though, a bad TPS sensor will cause the car to stutter when coming off idle or cause some stumbling when dropping (returning) to idle.
Throttle cables can be a bit harder to trouble shoot. You can try rerouting the cable to see if that changes anything or again, just replace it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 10, 2014
#13
  • Jul 10, 2014
  • #13
The likely culprit is a TPS that has the creeps. TPS sensors have a bad habit of starting out with the voltage at normal range .5- 1.0 volt and creeping upward. When this happens, the idle speeds up until it maxes out. Turning the ignition switch off and back on when it is creeping resets the computer and the process will slowly start all over again.
The tip off is to put the transmission in neutral when it care is accelerating by itself and see where the idle RPM is. If it is higher than normal, then the TPS has problems. Replacing it is the only cure.
Setting the TPS: you'll need a good Digital Voltmeter (DVM) to do the job. Set the TPS voltage at .5- 1.1 range. Because of the variables involved with the tolerances of both computer and DVM, I would shoot for somewhere between .6 and 1.0 volts. Unless you have a Fluke or other high grade DVM, the second digit past the decimal point on cheap DVM’s is probably fantasy. Since the computer zeros out the TPS voltage every time it powers up, playing with the settings isn't an effective aid to performance or drivability. The main purpose of checking the TPS is to make sure it isn't way out of range and causing problems.
The Brown/White wire is the VREF 5 volts from the computer. You use the Gray/white wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS. Use a pair of safety pins to probe the TPS connector from the rear of the connector. You may find it a little difficult to make a good connection, but keep trying. Put the safety pins in the Dark Green/Lt green wire and Black/White wire. Make sure the ignition switch is in the Run position but the engine isn't running.
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks.
(copied from MustangMax, Glendale AZ)
A.) Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
B.) When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
C.) Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
D.) The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
The TPS is a variable resistor, must like the volume control knob on a cheap radio. We have all heard them crackle and pop when the volume is adjusted. The TPS sensor has the same problem: wear on the resistor element makes places that create electrical noise. This electrical noise confuses the computer, because it expects to see a smooth increase or decrease as the throttle is opened or closed.
TPS testing: most of the time a failed TPS will set code 23 or 63, but not always. Use either an analog meter or a DVM with an analog bar graph and connect the leads as instructed above. Turn the ignition switch to the Run position, but do not start the engine. Note the voltage with the throttle closed. Slowly open the throttle and watch the voltage increase smoothly, slowly close the throttle and watch the voltage decrease smoothly. If the voltage jumps around and isn’t smooth, the TPS has some worn places in the resistor element. When the throttle is closed, make sure that the voltage is the same as what it was when you started. If it varies more than 10%, the TPS is suspect of being worn in the idle range of its travel.
TPS will not go below 1 volt
Note: Make all resistance checks with the ignition switch in the OFF position. Failure to do so will result in incorrect results and may possibly damage the meter.
Engine mounted sensor circuit: Check the resistance between the black/white wire on the TPS and battery ground. It should be less than 1 ohm. Higher resistance than 1 ohm indicates a problem with the 10 pin connector, computer or the splice inside the main harness where the wire from the 10 pin connectors joins the rest of the black/white wire.
See the graphic for the location of the 10 pin connectors:
See the graphic for the 10 pin connector circuit layout.
Unplug the white 10 pin connector to do some resistance testing. It is good time to clean the connector pins and examine the connector for corrosion, broken wire or other damage. See http://oldfuelinjection.com/?p=85 for help in this department.
If the resistance on the TPS Black/White wire and pin 1 of the white engine fuel injector harness 10 pin connector, is more than 1.0 ohm, you have bad connection or broken wiring. Repeat the test using the pin 1 of the white body side 10 pin connector and battery ground. You should have less that 1 ohm. More than that is a damaged signal ground inside the computer or bad connections or wiring.[/b]
Reactions: FastDriver
dubbsix
347
Katy,TX
Jul 10, 2014
#14
  • Jul 10, 2014
  • #14
thanks!
toyman
1,944
54
79
Vernon BC
Jul 10, 2014
#15
  • Jul 10, 2014
  • #15
Just note that the above from jrichker is for the '93 and earlier engines. Yours is a '94 so the TPS colors are the same except for the ground which is gry/red. TPS cannot be adjusted on the '94 and the spec range is from .65v - 1.25v. Also confirm that the reference voltage is 5v. If it's not remove and clean the battery to engine and engine to chassis grounds. This may help with the wiring.
Reactions: A5literMan and jrichker
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jul 10, 2014
#16
  • Jul 10, 2014
  • #16
dubbsix said:
Hi
Auto.
Hey
dubbsix
347
Katy,TX
Jul 13, 2014
#17
  • Jul 13, 2014
  • #17
Okay. thanks for your help guys!
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
