  • SN95 4.6L Mustang Tech
Accufab Intake
  • Thread starter Thread starter alfman9
  • Start date Start date Apr 12, 2004
A
alfman9
217
Florida
Apr 12, 2004
  • Apr 12, 2004
Thinking of a throttle body and pleumn for my 4.6. Was told that accufab was the best, but was wondering which size to get; the 70 or 75? Someone told me only get the 75 if I was going to add a supercharger and I was wondering why? Any info from personal experiences and install would be appriciated.
neoclasiccl
3,043
Help I can't see !!!!!!
Apr 12, 2004
  • Apr 12, 2004
Get the 75mm I have read several tests and the 75mm on N/A vehicles showed more horsepower.
Barker02GT
83
SC
Apr 12, 2004
  • Apr 12, 2004
The TB/Plenum combo from Accufab is what I plan to purchase next. I agree with the above, everything I have seen with the 75mm makes more power than the 70mm even on a N/A motor. Go ahead and get the 75mm! That's what I am going to do.
I found a site www.crmotorsports.com that has the combo for about $423, just in case you haven't found it cheaper anywhere else.
SkOoTcHe
24
pa
Apr 12, 2004
  • Apr 12, 2004
I just installed the accufab tb & plenum 75mm last weekend . And MAN what a difference not a low end it stayed the same but mid thru top end you can notice a really good boost in power... Now i gotta get the Mass air kit for more but just that kit alone did really good... i got it for 419.00 from coolblueperformance.com
A
alfman9
217
Florida
Apr 12, 2004
  • Apr 12, 2004
With the bigger throttle body, will the stock intake pipe fit around it? I have a volant cai on the way, will it fit? How easy is it to install? Ive heard different opinions on how the car idles afterwards.
pony_vert02
285
AUSTIN,TX
Apr 12, 2004
  • Apr 12, 2004
the inlet pipe will fit, only it will be a very 'tight' fit...loosen the clamp all the way, apply a little soapy water to the insides of the inlet pipe and squeeze it on...it will fit..i promise..check out this head to head comparison...the proof is in the pudding!...i am planning on getting a PROCHARGER system eventually, hence the larger T/B and PLENUM, but this is also an effective combo that you can use right now!
http://www.modulardepot.com/?show=articlesdet&aid=38
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Help Reading CEL Light
  • Mhalc1
  • May 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
Mhalc1
