Not having it pinned correctly fries ECUs. You can’t stick a 5-spd ECU into an original AOD car without repinning it first.
Needs to match the below diagram based on year and ECU.
More info here
This thread is a HOW-TO for the process of repining the o2 sensor harness to match ECU/Trans, in the event the car is swapped. See post 15 as to what the jumper should be repinned to.
Step one. Remove the o2 sensor harness from vehicle. I find it easier to do on a bench plus it allowed me to degrease and reloom the harness. You can do this in the car if you want...it's that easy.
Here's the default loop setup in my 1988 AOD car
First you need to remove the red clip. Lightly pry up with a small pick
Next, look down inside with a light and you'll see small...
