Accufab TB Question
  • Thread starter Thread starter 1105
  • Start date Start date Oct 6, 2005
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
Alright guys I need your help with a few questions. I'm converting my 95 over to the fox TB setup and I really wanted to get an Accufab 85mm TB for it. I picked up a TPS, connectors for it, and what I guess is the IAC (only other sensor on the TB)
I'm under the assumption that the Accufab TB does not come with either of these right? I havent really been able to find any good info about the TB if it comes with sensors or not but every pic I've seen it does not.
Anyone who has one can you tell me which sensors I'll need and possibly a price to buy new ones if needed? Thanks
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 6, 2005
  • Oct 6, 2005
The accufabs don't come with a tps or an IAC. I think you meant 75mm, not sure if they make an 85mm.
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
They make them up to 90mm.
Is this the IAC sesnor? There was something else inside the TB but I don't know if its part of the TB that stays in or part of the sensor. I know the TPS I got is right, just a matter of does it work or not.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 6, 2005
  • Oct 6, 2005
Thats the tps sensor and stock cut harness.
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
Is the IAC the big one that sticks on the side? If so I got that one too. So that is the complete TPS sensor and the harness that I'll need right? I got the other larger sensor (IAC i'm guessing now) and the wiring harness for it as well.
MattZ281LE
345
Purcellville, Va
Oct 6, 2005
  • Oct 6, 2005
I am converting mine also.
I just bought a new IAC sensor on Ebay for 7.00 Shipped still in the ford box.
The best way to get what you need is to find a junk yard with a fox car somewhat intact. and strip all the parts you need at once.
The plug for the IAC is the same as the 94-95. You only need the plug for the TPS.
There is an AWESOME thread on this.
Fox Swap
- Matt
Actually Accufab now has as lage as 105mm bodies.
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
Thats what I did, I stripped one car of the bracket, cable, and connectors, the sensors I got off of a crown vic because they looked to be in good shape. I'll check out ebay for that IAC sensor, because for $7.00 its worth buying a new one.
I thought I saw 105mm somewhere, but couldnt find the site again.
I
IntenseBlue
946
  • Oct 6, 2005
You don't need a throttle body that big.
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
  • Oct 6, 2005
I don't need an 85mm or were you refering to the 105mm one?
I might as well get a 65mm tb and be done with it. Thats what Grn has been recomending over on the 94/95 forums
MattZ281LE
345
Purcellville, Va
Oct 6, 2005
#10
  • Oct 6, 2005
  • #10
You only need an 85mm for Very large forced induction applications. I am only using a 75mm on my combo.
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
#11
  • Oct 6, 2005
  • #11
I'll be going 12psi turbocharged, later it'll be on at least a 347. I think the 85mm would be a nice size for what I have planned.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 6, 2005
#12
  • Oct 6, 2005
  • #12
What is your combo?
MattZ281LE
345
Purcellville, Va
Oct 6, 2005
#13
  • Oct 6, 2005
  • #13
Well.I would get what will work with your combo NOW. 12psi turbo a 75mm would be good enough. is that on a stock motor???? More info needed H/C/I???
1105
May 3, 2003
3,841
Daytona Bch, FL
Oct 6, 2005
#14
  • Oct 6, 2005
  • #14
Stock heads, cam, eddy intake, MP T70 turbo.
If a 75mm is good on a mild setup, the 85mm should be good on a boosted setup. Plus I don't have enough money to buy 2 TB's
MattZ281LE
345
Purcellville, Va
Oct 6, 2005
#15
  • Oct 6, 2005
  • #15
75mm works well for me....I wouldnt consider mine too mild. And you can always sell the one whenits time to upgrade.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 6, 2005
#16
  • Oct 6, 2005
  • #16
No need for that big of a TB.
I
IntenseBlue
946
#17
  • Oct 6, 2005
  • #17
75mm isn't mild, it's partially wild.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 6, 2005
#18
  • Oct 6, 2005
  • #18
75mm is fine for what you're doing. Just do NOT put it on w/o dremel matching the inlet. The edelbrock intakes have a 70mm opening so to effectivly use a larger tb, you have to dremel match it. Putting a larger tb than what the opening is is stupid and you create a wall for air to hit.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
