  • SN95 V6 Mustang Tech
adding tweeters to my system, please help
  • Thread starter Thread starter SilverBullet99
  • Start date Start date May 19, 2004
SilverBullet99
  • May 19, 2004
i have a 99 v6 stanger and i only had the premium sound system (not mach) without the tweeters. i installed a new head unit, and replaced all my speakers, but now i wanted to add tweeters to it. i was going to buy after market ones and put them right where the mach tweeters would go. im gonna get them w/ x-overs, so i dont need to amp them, but does anyone know how i could wire them? could i just run them right off my front speakers??
M
macatak60
46
  • May 19, 2004
my opinion
i've never installed them but are you using the head unit amp to power the 4 door speakers? if so i believe i would use a separate amp to run the 4 door speakers and the unit amp to run the tweaters
O
Onimere
24
  • May 21, 2004
dude you are all good, as long as you buy the right cross overs you can run them inline with the front speakers and maintain the proper ohm load. Your crossovers should have one input and two outputs. I have done exactly what you are doing, but i think i will just hop onto ebay and buy the mach1 housings to mount tweets in. It would probably look cleaner. When you do get crossovers make sure you dont leave them in the door cavity, they could get wet and short the system. Good luck and let me know if you need help.
seekjohn
23
Ontario Canada
May 22, 2004
  • May 22, 2004
tweets in mach460
i just bought the tweeter holders for my stang because i wanted to have the clean stock look too. just so you know, the speaker in the mach tweet kit looks like its about 2'' so youre gonna have to customize a recessed platform for the tweet to sit on so the grille will fit
P
Interior and Upholstery Door Speakers- found suggestion to go component, not coaxial
  • pindude80
  • Apr 21, 2025
Fox 5.0 Mustang Tech Apr 28, 2025
Mindseye007
K
Need help with 99 cobra mach 460 audio
  • kevinatd18
  • Mar 16, 2024
  • Mustang Sound & Shine All
2K
Mustang Sound & Shine All Mar 17, 2024
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
