Adj. Pressure Reg.??
  • Thread starter Thread starter 89CopCoupe
  • Start date Start date Jun 3, 2004
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 3, 2004
  • Jun 3, 2004
Installed FRPP 190 pump on stock '89 (exhaust only mod) & bought an Aeromotive adj reg. Removed old reg & appears the vac nozzle on the Aeromotive unit will contact w/ the EGR when I go to put it on?? Anyone have issues w/ this
Also bought a 24" length of 1/4" FI hose to run from the new reg over to a pressure gauge. Will this give me an accurate reading (using hose instead of line and the length)?
Plus, the paperwork on Aeromotive unit stated most OE regs are set to 43psi w/o vac line attached ..... they recommended setting theirs at 48?? I thought stock engine builds w/ 19# it was best to set around 40psi
Also bought a BBK reg in case I run into problems. Appears to have a smaller body & the vacuum nozzle is offset from the 1/8" npt port. Will my gauge thread right onto the side of the BBK unit & clear the EGR etc??
Please help, Thank you.
powershift351
225
Carlsbad, Ca.
Jun 3, 2004
  • Jun 3, 2004
I have the aeromotive afpr, and I would definitely run between 38psi and 44psi depending on what you have set-up
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 3, 2004
  • Jun 3, 2004
the gauge goes on the fuel line itself by the alternator in the schrader valve
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 3, 2004
  • Jun 3, 2004
Thank you for the replies ....... now i just need an adapter (1/16" m - 1/8" f) that goes between the schrader valve socket and the gauge ......
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
