Adjustable clutch cable..
  • Thread starter Thread starter ID89GT
  • Start date Start date Oct 19, 2008
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 19, 2008
  • Oct 19, 2008
How tight is the cable suppose to be? I went to finally do the first time start up and it will turn over and all but sounds like something is grinding somewhere and the clutch is the only thing I can think of by how it sounds
HISSIN50
34
129
Oct 19, 2008
  • Oct 19, 2008
I adjust the cable to zero lash. That is, I remove all the freeplay (and perhaps add a smidge of preload) and call it good.
White88T-Top
69
Tacoma, Wa
Oct 19, 2008
  • Oct 19, 2008
If its a chattering sound then its probably the throwout bearing making noise on the throwout bearing shaft. You will then need to inspect to see if it messed up the aluminum one and if it did then replace it with the ford aftermarket steal one from 5.0resto. Sounds like the problem I had with adjustable cables I could not find the right adjustment and kept snapping cables so I got a stock adjustable cable from 5.0resto and use the firewall adjuster an pawl from steeda. I think is has alot to do with the adjuster on the cable bending at a bad angle when the clutch fork is engauged because that were mine snapped. Hope you dont have to go though this its not fun.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
