summit sells the BBK piece, but was hoping for some quick input on whats the best piece out there??/
Anthony :SNSign:
Anthony :SNSign:
oh thanks, ill try and get ahold of Joe or Ernan then....HISSIN50 said:Anthony, get ahold of Joe (Vibe) or Ernan (I think they both run the Fiore FWA and quadrant) and ask if they could use their stock cables.
Or get ahold of Mr Fiorentino and simply ask. That's the way to know for sure.
Good luck.
yeah its between Steeda and Fiore at this point...I've just got to figure out what cables work with the Fiore and ill make my choice...the Steeda still comes with a cable btw....Stangster5.0 said:Im not sure if it still does,but I got the steeda firewall adj quadrant 2 years ago,mine came with a cable.The only problem ive found with this unit is you have to drill and tap a hole for a set screw,otherwise it loosens under vibration over time.Take a close look at whatever you buy and see if it has a way to lock the adjusment to avoid this.I think I payed 119 through summit if im not mistaken.
