Adjustable lower control arms?
  • Thread starter Thread starter stang8urimport
  • Start date Start date Feb 15, 2006
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 15, 2006
  • Feb 15, 2006
Ok, I want to get some lower control arms because I will be taking apart the rear suspension to refreshen it (isolators, and maybe new Saleen springs if they are weak. I will take them to a machine shop to have them tested for spring rates). I was looking at these: http://cgi.ebay.com/ebaymotors/1979...cmdZViewItemQQcategoryZ33583QQitemZ8039056180 . I don't wany poly bushings, as I know they bind. I like the adjustable part, but what do I adjust them to? I will probably leave them the stock length. I figure you can change pinion angle with these like you can with adjustable uppers.... Tell me what you think of these arms.
Nick
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 15, 2006
  • Feb 15, 2006
ttt
sweet88gt
334
Venice FL
Feb 15, 2006
  • Feb 15, 2006
I have a set of UPR adjustable lowers and they seem to be basically the same. I set the arms to stock length and had some wheel hop at the track. Readjusted them longer than stock and it went away. I would say that if I could do it over again I would pick the arms that can be adjusted on the car. A package of lowers and uppers designed to work together would be my pick.
ninety15.0
1,336
  • Feb 15, 2006
Sorry to thread jack but has anyone seen those tubular granitelli uppers and lowers on ebay with poly bushings for like 149$ for the set. This seems really cheap but they dont look too bad. How would this package be in terms of performace/quality? also if i were to get a better name brand i would only be able to pick up either uppers or lowers, which should i get? the lowers? thanks for the help.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 15, 2006
  • Feb 15, 2006
There is a button that says "New Thread". Thanks.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 15, 2006
  • Feb 15, 2006
How much longer did you make the arms then stock? Thanks. Nick
Euphoric306
905
  • Feb 16, 2006
poopdawg- i believe the adjustable lowers adjusts ride height and such
Curse
791
El Paso, TX
Feb 16, 2006
  • Feb 16, 2006
You are thinking a bout weight jacker type LCAs. The type PoopDawg is talking about, help you center the differential after you have adjusted the pinion angle.
Euphoric306
905
  • Feb 16, 2006
my bad, i didnt know there was a difference
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Feb 16, 2006
#10
  • Feb 16, 2006
  • #10
So do you guys like these arms? Got QA1 ends, which are top quality. Any ideas?
sweet88gt
334
Venice FL
Feb 16, 2006
#11
  • Feb 16, 2006
  • #11
For the money they will do. I will say I would pick a brand that has been around with a well known track record of quality and fitment. My UPR lowers are not what I would say the best but they do the job. Its your call.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
