Adjusting clutch cable?
  • Thread starter Thread starter carbed 85 gt
  • Start date Start date Dec 10, 2005
carbed 85 gt
121
Honolulu HI
Dec 10, 2005
  • Dec 10, 2005
Hey I just got done with my T-5 swap. At first the trans was hard to put in any gear, I installed an adjustable cable and it is better now. I still have a situation where it seems like I need extra effort to shift 1st or 2nd , and 2nd grinds on quick shifts. I dont know where to check my air gap on my clutch or how far I should tighten down the nut on the adjustable cable. Any suggestions?
HISSIN50
34
129
Dec 10, 2005
  • Dec 10, 2005
Where is the point of engagement? Is the pedal near the floor or around the middle of its travel?
You want a slight preload on the cable, but if the clutch adjustment is off, it should affect all gears nearly the same.
Good luck.
carbed 85 gt
121
Honolulu HI
Dec 10, 2005
  • Dec 10, 2005
The engagement is about mid way, I loosend the cable a bit but not a lot of luck.
HISSIN50
34
129
Dec 10, 2005
  • Dec 10, 2005
If adjusting the cable to ensure full disengagement, one would tighten the cable (remove slack) rather than loosen the cable.
If your point of engagement was halfway up, it sounds like it was tight to start with. You could make it fairly tight to be super sure it is not an adjustment issue (I would do this, start it up and try it once, and then introduce slack - dont leave it like that or it can burn up the new clutch).
Otherwise, it might be a soft part issue inside the trans. You could try a different trans fluid (ATF) - synthetics can kinda help out a bit.
Good luck and bump for ya.
carbed 85 gt
121
Honolulu HI
Dec 10, 2005
  • Dec 10, 2005
Yeah I just got this trans for the swap last week and was kinda afraid of this happening. It has new atf in it and a TRI-AX shifter with the plastic cup installed in the trans for the shifter "ball" to sit in.
Henceforward
The Avatar Master
485
  • Dec 10, 2005
Do you have an firewall adjuster?
I use this and it helps.
Plus the double hook quadrant.
I would run a regular FORD OEM non adjustable cable, and work from the firewall adjuster.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 10, 2005
  • Dec 10, 2005
i do not recomend running an adjustable cable and a firewall adjuster. man what a pain in the but getting the proper adjustment between the 2 of them.
Henceforward
The Avatar Master
485
  • Dec 10, 2005
I agree, that is why I went with the non adjustable. CJponyparts sell the OEM cable and the fork for cheaper than a cable alone.
$44
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 11, 2005
  • Dec 11, 2005
yah i think i want to go back to a oem clutch cable with the firewall adjuster. i sure to like the aftermarket clutch quadrent though. stupid woren out teeth on my plastic factory one was killing me. i would always have to pull over and re adjust it.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
