adjusting rockers
  • Thread starter Thread starter blackjackbender
  • Start date Start date Nov 12, 2005
blackjackbender
36
  • Nov 12, 2005
anyone have any tips on adjusting rockers or know of a writeup on this?
have never done this before so have no past expierence. I was told i want to remove the valve covers, run the engine with the rockers loose and tighten the bolts just when they snug up the rockers.
thanks
Ty
iskwezm
4,159
20
79
Rowland Heights,California
Nov 12, 2005
  • Nov 12, 2005
If you have a old valve cover,you can cut the center out to reduce the amount of oil spilling when it runs,but lossen them up till they "clack" and then slowley tighten till the noise stops,that is zero lash,then go another 1/2-3/4 turn
I prefer to do mine by pulling the plugs and putting each cylinder to TDC and and adjusting my lash that way(solid cam here)
69Rcode_Mach1
1,473
Salt Lake City, Utah
Nov 13, 2005
  • Nov 13, 2005
I would do it the way iskwezm said. It is easy and very accurate, plus you can listen to the engine and how it is running. It makes it easier to pinpoint error. I had a lot of problems because my valves were adjusted incorrectly. I am going to go to the junkyard this week and get an old valve cover to hack up.
thehueypilot
1,084
Medina,Tennessee
Nov 13, 2005
  • Nov 13, 2005
Try the latest Mustang Monthly Magazine (Dec 2005) Pg 44 Valve Adjustment. I agree with this article......1/4 turn max.
180 Out
375
  • Nov 14, 2005
Do not try the engine running method. It's messy, smokey, and confusing.
Why are you asking anyway? If you just have a single ticking sound or two, try some Marvel Mystery Oil; it may just be a stuck lifter and this stuff may clean it up and make the ticking stop.
What engine and cam do you have? The procedure varies according to whether you have an adjustable valvetrain or a solid cam.
If you've got an adjustable valvetrain and a hydraulic cam, just keep in mind that what you're trying to do is set the plunger at the halfway point between the top and the bottom of its travel, with the cam on its base circle. I just bring the #1 up to TDC compression, and tighten the rocker nut down while moving the pushrod in an up and down motion. When the up and down runs out of room, I switch to a twirling motion. When I feel drag on the twirling -- that's zero lash -- I give it a 1/2 turn. Then I do the other valve. Then I crank the engine 90 degrees and do the next cylinder in the firing order, then the next, etc. If I get confused about whether I've hit zero lash, I just loosen up the nut and start over. You'll get good at it pretty quickly.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
C
Valve stem tip tap?
  • Coolen
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2025
