Hey guys. I just need a quick answer. I just did rear brakes on my 02 GT and now the e-brake has rediculous slop. I want to not only adjust it, but make it tight.
How do you adjust the e-brake on a 2002 GT? Thanks
edit: I've been searching through some previous threads on here and I "HEAR" that you can not adjust the e-brake. Which i dont fully believe, as i've taken the center console compartment box apart to access the e-brake and I can see the handle has a toothed selection on it, which leads me to believe it is SOME HOW adjustable.
Not to mention the fact that I just put brand new pads and rotors on the rear and the e-brake is sloppy as hell. It BARELY holds the car and if its a steep hill the e-brake doesn't hold at all. There HAS to be a way to tighten it.
Any help appreciated. thanks
