I am getting ready to start up the stang after a very long project fraught with divorce, two family tragedies, and a couple of financial setbacks. I have compiled a quick list of things I think I should do, as I get ready to start it up and actual startup.
1. Check every bolt front to back for proper torque specs
2. Check every bolt again
3. Check all wiring connectors
4. Place four fire extinguishers around the car
5. Connect the battery to find any immediate shorts (knock wood)
5. Fill with fluids
6. Use drill with starter gear extension to pump up the oil
7. Turn key to on, and check for fuel pump activation
8. Check for voltage at solenoid with key on
9. Turn key... (wait... cross fingers, say a Hail Mary) ... to on
And this is where I need to know what to do;
I know that the new 1.6 roller rockers on the AFR headsmay need some adjusting. Should I wait until the car runs for some time?
If the car does start (when the car starts the first time - wishful thinking), should I just let it run?
How long should I let it run? On most of the build shows, it seems like they only let it run for a short period of time then shut it down. Why?
I have been told that the new heads and cam will need to be "broken" in using conventional oil. (the bottom end was never opened up/broken down aside from the cam), is this true? Broken in under driving conditions? or at idle, in park, revs?
Thanks for any insite or personal experience you can provide.
Best to all who have helped me on this project.
5. Fill with fluids
