junkyardwarrior
Well-Known Member
- Jan 10, 2011
- 398
- 119
- 63
I went through this
a number of years ago I bought one of those homer depot ryobi or whatever brand it was, gas pressure washer with a honduh engine on it. While it did the job, I found out later on that it wasn't great. They advertised like 3000 psi and 2.4 gpm I think it was. GPM was low. It developed a pump problem (and mind you, I am really good about taking care of my stuff), and I found out that replacing the pump costs nearly as much as replacing the entire washer. Sold the washer on the market and bought another one. Same unit. I mean, I did get 5 or so years out of it. That one too died in the same manner. Plus, it was hard to start, and on the noisy side. They're all noisy but it was louder'n I thought it should be.
At the time I worked for a Yamaha powersports dealer. They had a Yamaha PW2800 come in and they issued it to the shop guys to wash equipment off. I used it a few times and was impressed with it. Quieter, easier to start, for the most part it was problem free for a number of years, other than there were two morons that kept running over the hose with the forklift, which destroyed it each time. I ended up buying one of those yamaha pressure washers. Same model, just the newer revision.
I've had it for almost 8 years now. I use the heck out of it! Deck, house, driveway, cars/trucks, mower, etc. Every time it's used, when it's done I put pump saver into the pump and circulate it. Ain't had a moment's trouble out of it. The ONLY complaint I have is that the hose is a little stiff after a few years, solvable by going to a hydraulic hose shop and having them make a hose out of hydraulic hose. I just ain't done it yet, and won't until the hose fails.
Couple things I like about it. Quieter. CAT pump. The wheels never go flat, and they're large enough that they roll easily. The frame is built well. Also the handlebar assembly folds down, and it folds FLAT across the top so that you can stack stuff on top of it if needed. Sort of a neat feature. Soap dispenser holds a gallon. The wand tip is interchangeable but I have never found a need to change the tip-the tip it comes with is rotary and you can choose what pattern you want just by turning the rotary selector. 20 deg, 40 deg, soap jet and soap fan, and low pressure. The low pressure setting is what I use most of the time. You get volume but not a lot of pressure and the volume does most of the work on loosely packed stuff. AND-I made (you can buy them too) an undercarriage washer out of some scrap,2 skateboard wheels, 4 nozzles, and a wand extension. Picture below of what I'm talking about. I use it to wash under the mowing deck of the mower, under the cars/trucks, etc. Great little attachment! You guys in the salt belt might benefit from this to help warsh some of that stuff off of your vehicles after winter's gone. The second attachment I have is a 15" surface cleaner. If you are washing a deck or a driveway or whatever, these things will cut the time down dramatically! It's effortless to use too, just like sweeping the floor but even easier as when the nozzles are turning with water pressure running through them, it also helps to lift the attachment a little, which reduces the amount of weight that you are having to push/sweep across the surface.
yamaha also has a 4000 psi version which is way more than I would ever need.
And--at work they have a 25 year old brushless 120v electric washer, I think it's a Mi-T-M or something like that. 1800 psi, but something like 3.1 gpm. The volume is high pressure is not. Boy am I impressed with that thing! It's real old, and is used several hours every day for 6 days a week for the last 20 some odd years. If I didn't already have my yamaha I'd probably buy one.
