  • 1994 - 1995 Specific Tech
advise on tapping the oil pan
  • Thread starter Thread starter donkey_punch
  • Start date Start date Jul 31, 2008
donkey_punch
565
northern****ingjersey
Jul 31, 2008
  • Jul 31, 2008
it seem staright foward, but i **** up everything i touch. and the last thing i need to do right now is ruin my oil pan. i really would hate to yank the motor to change the pan, with out the funds to go all out, just because i couldn't tap a line to the pan right.
any advise, walk through, write up , video would be great
Thanks
Joe
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jul 31, 2008
  • Jul 31, 2008
I havent done it but search here, 5.0 section, corral.net, and hardcore50.com .
Im positive you can find more than enough necessary info!
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Aug 1, 2008
  • Aug 1, 2008
Tap Mustang Oil pan
TurboSnake95
1,402
Spanaway, Washington
Aug 1, 2008
  • Aug 1, 2008
Make sure you put grease on the drill bit, helps collect alot of the shavings when drilling the hole.
donkey_punch
565
Aug 1, 2008
  • Aug 1, 2008
thanks for the respones, and for the link. i'm going to need some liquid courage, and some luck, lol
juiced_94gt
1,143
Southern California
Aug 2, 2008
  • Aug 2, 2008
hold a magnet next to the bit...it will collect the shavings, that and the grease is the best way.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 2, 2008
  • Aug 2, 2008
Or better...if you can have someone hold a shop vac up against it, you should get almost none.
WHen I drill out lead in my pinewood derby cars to adjust the weight, I hold a shop vac against it and almost NO lead is left on the drill press.
Good Luck!
RC
Stanger007
2,015
Baton Rouge, LA
Aug 2, 2008
  • Aug 2, 2008
I'm a fan of using progressively larger punches then greasing a tap every turn or so to do the deed.
Works great, you won't get any shavings in the pan and you get a much better "bite" by using punches vs drilling IMHO.
Wes
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
A
88 Foxbody Starts but Stalls When Warm Please Help
  • airforcerob
  • Apr 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
