aerostar aluminum driveshaft swap!
I paid $12, yes twelve dollars for mine at the local Pull-A-Part. I bought another one just cause it was there. I used stock Mustang U-Joints on my 91. You'll need to re-use your differential mounting plate as the Aerostar's plate is different. I have it plugged into an AOD if anyone is curious. I didn't know they were so pricey....There are 2 more in the yard right now so I'll probably have to go pull them and add to the hoard.
I'm just going to use the mustang tail stock some mustang u-joints and the mustang yolk and bolt it all up !! will let you know how it goes! should get to it either tomorrow or the next day! I'm in the middle of polishing up my G3 alt that i pulled off a 97 mustang at the wreckers! was sitting out in the open on a car with no hood! so it needed some work !so me being me i decided to polish it! wow i have about 4-5hrs in it already! will post back about the u-joints and the install!
no pics yet roland ! im still working on it to clean it up! you know what our winters are like here! and it came off of a 97 3.8L mustang so it was a daily driver untill it got sent to the JY! so i had all kinds of salt in it and tons of crud build up! so im in the process of cleaning her up and making it look brand new again! i know it works i had them test it on there tester before i bought it so once i get her all done ill take some pics of it and post them! but like i said i got 4-5hrs into it all ready still got some to go! looking good though! needs acouple more hrs of dremeling and some sanding and should look mint!:nice:
ok i went to napa got the u-joints for a 91 mustang they look like there going to fit! but im in the middle of cleaning up my 3G altenator! i did another sanding of the altenator today looking good real good! im going to do one more sanding tomorrow and it should be ready for polishing! i will post pics when its done! so far i have about 8 -10hrs into the dremaling and sanding!so as you can imagaine my back is aching and my hand is numb from the sander!!! so im taking the night off!! anyway i will post pics of the alt when its complete!:canada:
and like i said i bought some but i bought 91 mustang u-joints from my napa here! i have checked them and they look like they are going to fit but because i started working on the alt , id rather finish it first then move on to the drive shaft! I'm not one for having 5 different projects on the go at once! when the alt is done it will be on to the driveshaft! I'm going to go into the garage and take some pics now of the drive shaft and the alt so i will post asap!
