AF lean between shifts
Blue89Hatchback
161
Is the AF ratio supposed to go lean between shifts and when you let off on the throttle? Iv'e datalogged my AF and it goes over 20/1 between shifts and also backfires in the exhaust. This is not a mod motor but a 5.0. Need some help with this please. Thanks.
If you let off the throttle under load and use the compression of the engine to slow down, it will go lean- very lean. And that's fine. However, I don't see why it would between shifts. That may be a sign that something is wrong somewhere, but I wouldn't know what. I just haven't observed it on mine, and it doesn't sound right. Back to the top...
