AFR 165 heads on older shortblock
  • Thread starter Thread starter my9302002
  • Start date Start date Nov 17, 2009
my9302002
88
  • Nov 17, 2009
Thinking about installing a set of AFR's on a 302 shortblock rebuilt back in the 1980's. Will this cause any problems? Car is running well, no oil consumption, putting out about 230hp right now with the old 4v heads. Probably about 20,000 miles since the rebuild.
D
D.Hearne
11,730
south louisiana
Nov 17, 2009
  • Nov 17, 2009
If you DO have 4 bbl 302 heads, then you'll see a drop in the compression ratio. The 4 bbl 302 heads had 54 cc chambers. The AFR's are probably, what? 58, 60 or 64 cc's?
68EFIvert
639
Camas, Washington
Nov 17, 2009
  • Nov 17, 2009
I have a set of AFR 165's with Pedestal rocker part #1472 IIRC. They work on my roller shortblock with stock pistons and a cam with .521 lift just fine. The intake gasket is in fact a 1250 and the cc's are 61 for pedestal heads. Great heads, you will like them. They have worked well for me but I am in the process of building a Boss block based engine and need larger heads.
rbohm
6,698
550
204
tucson,az
Nov 17, 2009
  • Nov 17, 2009
i believe that the 165's had 58cc chambers, but the added flow will more than make up for any power lost by the lower compression ratio.
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
