afr 185s or ported e7s?
  • Thread starter Thread starter Modular2v
  • Start date Start date Jul 21, 2005
1 of 2 Next Last
Modular2v
3,222
23
99
oklahoma
Jul 21, 2005
  • Jul 21, 2005
ok im a college kid on a budget....my machinest told me he can fully port my e7s, put bigger valves in and some springs for 450.....does anyone know if they are really worth porting or would i be better off saving up for the afr 185s......i will be running these on a carbed 331....
another thing, what kind of times should i be running with fully ported e7s/afrs, full manual valve bodied AOD, holley 750 carb, victor jr intake port matched to heads, .500 lift cam and 4.30 gears on bfg drag radials? The car only weights 3025lbs and keep in mind that it is a 331
O
onebad12
17
  • Jul 21, 2005
I have a set of AFR 185's for a DSS bullit 308. Save your money up for the 185's.
Modular2v
3,222
23
99
oklahoma
Jul 21, 2005
  • Jul 21, 2005
are they for sale?
VG30DE
364
Dudley, MA
Jul 21, 2005
  • Jul 21, 2005
E7's = way cheaper, but E7 = stock
bigger valves are still real small
ported until failure is still not as good as an aftermarket casting.
For the money, get a junkyard cobra motor or 96 explorer motor for $300-500 and take the heads off that... the GT40's are still better than ported stock. If you want a serious setup, save up for a power adder or get some good heads.
cleanLX
976
537
144
Jul 21, 2005
  • Jul 21, 2005
you cannot compare the 2 heads.
unless you mechanic can give you flow numbers, or show you previous customers success with the E7's, I wouldn't let him touch a set.
for a 331, I think it'd be a shame to put on E7's of any varation compared to afr 185's.
a 3000lb car w/ proper 331, afr185's, built auto, 4.30's and bfg dr's should be well into the 11's, even with a small cam.
Modular2v
3,222
23
99
oklahoma
Jul 21, 2005
  • Jul 21, 2005
i have everything but the heads figured out....other than that the car is ready to go!......so you think it would be worth it to wait a couple months, save up, and buy the afrs?
Curse
791
El Paso, TX
Jul 21, 2005
  • Jul 21, 2005
I went the ported e7 route and wish I would have just bought some Eddy or TW heads. I did notice a difference with the ported heads, but my friend has a 93 GT with fewer mods than me but with AFRs. I took a ride in his car and . Not only will they outflow ported E7s but they weigh a lot less.
Paul Perreca
1,085
  • Jul 21, 2005
but afrs are more than twice the cost of porting the E7's -
I've got one of the best machinest around here and he's my dads friend - i think he could do a great port job on my E7's
What does port until failure mean?
Paul Perreca
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 21, 2005
  • Jul 21, 2005
Afr's hands down. You may be able to find a used set of heads as well. I'd strongly consider swapping the afr valve springs out as well!! I can understand using your E7's due to money reasons, but for a 331 why put money into them?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 21, 2005
#10
  • Jul 21, 2005
  • #10
If that is all you have and you want to get your car running, get the ported stockers, you can always sell them later.
The fact is that the ported stockers will perform really good if the porting is done properly but not near as well as AFR185's.
I ran Thumper E7's, ported with lots of work on the bowl sides, 5 angle on stock valves, upgraded double springs. They performed very well, I was trapping 85mph in the 1/8th mile with a 8.4 ET and this is with a worn out motor with only boltons. I sold them and now have a set of TFS's and I am building a new motor.
sunil6784
620
Boston, MA
Jul 21, 2005
#11
  • Jul 21, 2005
  • #11
You're a college kid on a budget and you are modding two cars? Man, i'm in college and i'd love to be in your position!
Modular2v
3,222
23
99
oklahoma
Jul 21, 2005
#12
  • Jul 21, 2005
  • #12
well i have had the gt for over two years and have thrown money at it when i can....i put 11gs down on the gt and just got it payed off 2months ago, im currently done modding the 03 until modular parts get cheaper and i get out of college....so thats when i decided to buy a fox and start modding it.....already have the fox with new paint, built aod and the 331 is sitting topless in the car right now awaiting heads....i still owe 700$ on the 331 (i love having good credit) i saved myself alot of money knowing how to install everything myself.......sometimes college just seems like it is holding me back from making money oh well only two and 1/2 years left
L
luckythirteen13
648
Anaheim, CA
Jul 21, 2005
#13
  • Jul 21, 2005
  • #13
get the afr's. i have 165's and love them. worth every penny
Modular2v
3,222
23
99
oklahoma
Jul 21, 2005
#14
  • Jul 21, 2005
  • #14
so do think my car would be capable of low 12s with all those mods?
K
Kerpal
400
#15
  • Jul 22, 2005
  • #15
Werd... I have a hard enough time paying for gas, insurance and repairs at the moment.
My vote would be the AFR's, might as well build it right. With a 331 you can really take advantage of the better heads.
Scorcher2005
883
South Carolina
Jul 22, 2005
#16
  • Jul 22, 2005
  • #16
Paul Perreca
until there is no possible way to port anymore
Katmandu
302
Troy, Ohio
Jul 22, 2005
#17
  • Jul 22, 2005
  • #17
You NEED to go here -->> www.thumperoforangepark.com
MeanMussy
581
Louisville, KY
Jul 22, 2005
#18
  • Jul 22, 2005
  • #18
If you want to improve performance, and stay around the $400 range, look for a set of GT40 heads (not GT40P, you'll end up buying new headers for those). They're on 93 Cobra's and Lightnings (351W).
I'd place the GT40s somewhere between ported E7s and the AFRs (probably closer to the E7s than they are to the ARFs though...).
If you're near WI, I have a set of GT40s lying around.
Modular2v
3,222
23
99
oklahoma
Jul 22, 2005
#19
  • Jul 22, 2005
  • #19
i was going to get the gt40ps until i found out the spark plug angle would cause me to have to get new headers....i guess its time for some afrs
Modular2v
3,222
23
99
oklahoma
Jul 22, 2005
#20
  • Jul 22, 2005
  • #20
since i turned 21 my insurance was cut in 1/2! 331$ every six months!!!
1 of 2 Next Last
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • Locked
SOLD 357 Dss Running Engine
  • Sgtshanahan
  • Jun 26, 2013
  • Engine and Power Adder
Engine and Power Adder Jun 26, 2013
Sgtshanahan
K
New To Stangnet And Foxbodys
  • k8wdx
  • Mar 17, 2014
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2014
1968stang
Compression & Power Adders
  • Old Skooler
  • May 10, 2012
3K
Fox 5.0 Mustang Tech May 14, 2012
srtthis
