Jason@AFR said:Hey guys, figured I would drop in my 2 cents….
Fiveoho, it was good talking to you, call me back anytime.
The other person you spoke to was Scott, he is right and I agree that you have a good combo. Until you mentioned the fact you only wanted to turn 55-5600RPM, at which point with that cam I doubt you would have even seen peak power yet. Especially when considering the rest of that combo you certainly wouldn't be using the better part of the "Curve".
I am ok with the decision to run the 185's on a 306, there are quite a few guys that have run them on 302's after notching pistons and 306's without almost any complaint of the fabled "No power" down low. I am sure most will agree your power curve, drivability, MPH, and ET are all because of your COMBINATION, not because you bolted on 1 part. So with that said, why would someone look at only one part to effectively "Kill" the combination? I do feel that you should have gotten 165's, but does it make the difference in the world? No. Are you still going to have great power either way? Yes.
Not for nothing, but you wont know which is better until you have the opportunity to use them on the same set-up back-to-back, which is probably why we don't get complaints on the larger head small motor set-up, the owners didn't have anything to compare it to except stock.
You have a great combo, just not for what you were going for.
Give me a call or drop me an e-mail if you have any further questions, Jason Dow
didnt expect to see you post...glad you did. im going to try and give you a call back this evening if at all possible. i do appreciate you helping me. i want to talk more about cam selection and possibly doing away with the 306 idea and going 331. i was just a little confused yesterday when i called and spoke you then scott. scott was a help to, i just felt like i sort of got 2 different opinions. i guess you were just saying for what i want, that combo isnt in my best interest.
if i decided to keep the same combo in 306 form and change the camshaft...will that make a world of difference as far as getting that power in a broader curve?
if i decide to go 331 can i keep the exact setup with the TFS 2 cam included and be more suited for what i want? will those extra cubes of a 331 help put the power in a better broader place? or should i still choose another cam?
thanks again!
