I was doing my usual search of 302 build ups to find a good idea to copy and get some real power and I think I found a good one.
What I have: 302 from a '69 with a RV cam, hypereutectic pistons, stock intake, stock heads, headman headers, T-5. I have no idea as to my rear gear or my compression. I have PS, plan on adding PB, Removed AC (It's cold enough in Sweden) and am installing a 120Amp alternator and would rather not use pulleys because I need all the electrical power I can get to power my accessories.
Well, I want the most power possible without having to stroke the engine. I want to find a combo or heads, cam, intake manifold, carb and possibly new headers. If anyone can help me think of a good setup, please speak up. as for what I want, I want to be able to kick anyones %^& that comes up next to me. The most HP possible without a stroker kit or changing out the engine. The latest build up I saw was
http://www.carcraft.com/techarticles/116_0307_ford/
and they praise AFR heads like they are the Holy Grrrrrrail, but my block is hydraulic flat tappet, and these heads say they are roller, anything I have to do to make it work with my engine? and if I have to go flat tappet, I know roller tip rockers would be better. I was thinking the 185cc non-emission.
I was also wondering if I should go dual plane like the build up or if a single plane would give me more power, and what cam teamed up with these heads and intake would give me the best power, and one day be able to manage a paxton 1200. That will be some time off, but it is a future plan. I also have stock fuel water and oil pumps, should I upgrade those?
Well, I gave as much info as I know to minimize the flames and requests for info I do not know
