Hey guys, I have come to the conclusion that I have bent my intake valves, I am running a stock bottom end with a stock cam, I installed afr 165's 1400series 61cc with a 7/16ths stud upgrade coupled with comp cams alluminum 1.7 rockers. I have no compression on most of my cylinders, what the hell happened, are the 1.7 rockers too big with the stock cam, the guys at afr told me I would have no problems, what are you guys running?
Did you do a compression test? If you have an air compressor, remove all spark plugs, close the intake at the TB and run air through one of the cylinders, if air comes out the other spark plug holes, that will be a sure indicator.
