Anyone with a stock short block running AFR165s and a FRPP E cam? I've got the stock pistons and want to make sure the piston to valve clearence will be ok. I'm planning on using 1.6:1 rockers.
I thought this site was about mustangs.
5.5" lift intake and 5.6" on exhaust
oh, to the second guy, I'm sorry I can't answer based on personal experience, but it was my understanding that AFR185s require piston notching, which any machine shop should be able to do for you.
He was referring to a spam post that you can no longer see.I'm not sure I get it...
You mean you had more valve lift than you had stroke?![]()
lol, yup, that cam was a bad MFerHe was referring to a spam post that you can no longer see.
That's the secret
How much does the compression ratio increase with the 58cc heads verse the 60cc heads?
