Afr185s???
  • Thread starter Thread starter ls1beater4eva
  • Start date Start date Oct 2, 2006
ls1beater4eva
334
mooresville
Oct 2, 2006
  • Oct 2, 2006
ok well i have a guy willing to sell me a brand new set of afr185s wich i think would work really well with my systemax2 intake and tfs 1 cam and 150 shot? but i want to know what some of you other mustang owners think about this set up is a 5spd and with 3.73. i currently have a set of knock off edelbrock heads on the car now. allso does anybody know what lenth pushrod i would need to run if i switch heads i have 1.6 blueracer rrs on it now studmounted. Please help thanks:SNSign:
2KsilverGT
354
Collinsville Va
Oct 2, 2006
  • Oct 2, 2006
Do you have aftermarket Pistons??? if not you will probly have to get valve releifs cut into the stock pistons. I bought some 185's and my piston to valve clearance was crap. I ended up building a 331 to fix the prob. Some people say they will work on the stock pistons but I would check it with clay personally. AFR valves are not cheap. Other than that i'm not sure if you would see that much difference between the two heads. Afr's would probly make more power but I dunno how much more.
ls1beater4eva
334
mooresville
Oct 2, 2006
  • Oct 2, 2006
ok well i have the 202 /160 valves now i have a stock shortblock but have had the pistons notched for a x cam that i was running at the time with these heads so im not really worried about that im more so trying to cheat and find out if its worth the head swap and if so what lenth push rods i need .
304billet
315
  • Oct 3, 2006
do the 185's port matched to a 1245 gasket, Holley systemax port matched to a 1245 gasket, and ur X cam.
there is a great mismatch in port design between the 185's and the Holley. Been there I know firsthand.
The TFS stage 1 is a tiny cam. use the X cam or comp cam XE282HR.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
