After Driving for Awhile, In "D", tranny Slips into Neutral Under Load..
brentwoodboy
472
Brentwood, TN
I posted before about my Manual Lever Position or Neutral Safety Switch, but if I drive for 20 mins, and from a stop, if I floor it in "D", it disengages into neutral and doesn't engage again until the RPMS drop down...anyone know what my problem is?
are you sure it's kicking out of gear? Could it be slipping? When it engages back, does it shift hard or soft? You have a shift kit so it should jump if your rpms are above idle.
Might check your shifter cable and make sure it's adjusted right. If you are off a 1/4 inch it could be inbetween gears.
Well see, the thing is, it will only do it if its been running a while, like only if the tranny is hot. If I put her in "1" when its hot, it won't slip into neutral, it has to be in "D" to slip. When it does slip, it shifts back hard. Tranny was rebuilt about 1 1/2 years ago,.,, :(
