after storage what should I do
i would siphon all the gas out of the gas tank and replace with fresh gas, charge battery then remove coil wire and turn motor over a few times for approx 5 secs (don't overheat starter) to circulate some oil in motor. after this was done i would fire her up.
I'd put some Stabil in the gas tank to keep the gas good if you do not want to drain it. Pull the dist and prime the motor, turn the motor over 90 degrees by hand and prime it again, re-install dist and start it up. It would not hurt to pull the plugs and put a tiny bit of oil in the cylinders as well before starting.
