after the new quadrant install
  • Thread starter Thread starter rockyracoon
  • Start date Start date Mar 16, 2006
R
rockyracoon
874
27
49
margate NJ
Mar 16, 2006
  • Mar 16, 2006
I just installed an aftermarket single hook quadrant and firewall adjuster and the thing im noticing is if I put light pressure on the clutch with my foot I hear what seems to be the t/o bearing whining lightly.just wondering why I didnt hear it with the stock quad setup?
HISSIN50
34
129
Mar 16, 2006
  • Mar 16, 2006
Was there slack in the cable with the old quadrant/pawl adjustment? How much preload do you have now?
R
rockyracoon
874
27
49
margate NJ
Mar 16, 2006
  • Mar 16, 2006
I got about an inch on top of freeplay,the sound seems like it is the t/o bearing just when it touches the pressure plate,but like I said I dont remember hearing it before.
R
rockyracoon
874
27
49
margate NJ
Mar 16, 2006
  • Mar 16, 2006
im wondering if I had the cable adjusted too tight and maybe I bent a finger on the p-plate.
HISSIN50
34
129
Mar 16, 2006
  • Mar 16, 2006
I doubt you damaged a diaphram finger. The TOB's on these things are far from perfect, so it would not be surprising if the bearing is getting a little noisy under certain circumstances. It might just be dumb luck - though you should have been able to make it noisy with a little pedal pressure before too.
I got no great ideas otherwise. Bump.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • dan50
  • Jul 18, 2026
dan50
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
