I'm getting back into the mustang game, planning on buying my next project car in the next couple of months after about a 3/4 year hiatus. The whole point of my project is to do thing right, the first time.
I've come to the subject of gauges. The stock gauges won't cut it, and I've always loved the look of the black bezel/white face Phantoms.
Short of completely rewiring each gauges, I think I may work into the stock wiring. However, the t taps aren't how I want to do it. I don't mind clipping the old plugs, but what are my choices for plugs? I'd like to simplify the cluster, soldering 1/2 plugs (similar to stock) for easy install/removal. Better yet, is there a female plug that I can clip onto the stock male piece? (I can re pin it, but I need a physical plug)
Also, sending units, which would you suggest to upgrade? I only have experience with the water temp and oil pressure, and I plan on running 6 gauges (Spedo, RPM, water, oil, volts, fuel). I want to get the most out of my gauges (accuracy).
If there's nothing really going to fit my needs, I'm just going to wire each gauge, but I would still like suggestions on plugs for behind the dash for a clean install.
Thanks.
Thanks.
