Long story short, I am thinking about making my own cluster. I might use a Florida50 template, MC Machine template, or make my own....haven't decided yet.
I would most likely go with the same gauges the stock cluster has, speedo, tach, volt, water temp, oil pressure, and fuel.
My questions:
If I went with electronic gauges (except speedo), would I be able to simply use the ending wires from the stock cluster harness? I have a diagram of the connectors and would just repin all the leads into a different connector so I would simply plug in my gauges. I just don't know if the stock wire harnesses would have all the connections I would need to run electronic gauges.
As far as the speedo goes, the mechanical speedometers I have seen say they use a cable. Would I just plug in my stock cable and the aftermarket speedo would be accurate? Or would/could I use a 94+ VSS on my tranny and go with an electronic speedo?
My questions:
