  • SN95 4.6L Mustang Tech
aftermarket piston question
  • Thread starter Thread starter Rickey_Bobby
  • Start date Start date Dec 18, 2006
Rickey_Bobby
332
Sarasota, FL
Dec 18, 2006
  • Dec 18, 2006
I see that many companies offer a standard size in addition to the typical .020 and .030 oversize. Can you really just buy a std piston, hone the cylinder, and drop another one in? Seems to go against common logic...
Rickey_Bobby
332
Sarasota, FL
Dec 18, 2006
  • Dec 18, 2006
Damn, sorry about the triple post, don't know what the heck happened.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 18, 2006
  • Dec 18, 2006
Usually the machine shop will measure the diameter of the piston at a point exactly .500" above the bottom point of the skirt. Then along with the piston manufacturer's recommended piston to cylinder clearances, they can determine where to set the final hone.
The different piston manufacturer's clearancing can vary slightly, but they are all tested for their expansion/contraction properties at 72°F. It's an industry standard. There are two common types of aftermarket piston materials used that I am aware of....4032 and 2618. 4032 is called high silicon aluminum alloy. 2618 is also an aluminum alloy but it usually contains very little or no silicon. The 4032's are used in fairly mild apps, where the 2618's are used in more radical setups that don't see much street use.
The silicon in the 4032's helps to minimize the expansion/contraction so the recommended piston to cylinder clearances are usually a little tighter than the 2618's with no silicon. For instance, JE recommends a .0025"-.0035" (25 to 35 ten thousandths) minimum clearance with their particular 4032's. Then if you have a power adder setup, you will usually want to factor in an additional .001-.003".
You have also make sure that the particular piston you choose will have proper valve clearance, rod clearance, and the one some overlook...crankshaft counterweight clearance.
J
JimC
170
Duluth GA
Dec 18, 2006
  • Dec 18, 2006
Very informative laser. Thanks
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
