Aftermarket Speedometer
  • Thread starter Thread starter gcwh02
  • Start date Start date Sep 21, 2007
gcwh02
515
pottstown, PA
Sep 21, 2007
  • Sep 21, 2007
Im looking to install a new speedo with my new cluster I am going to assemble. What is easier to install, mechanical or electrical?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 21, 2007
  • Sep 21, 2007
Electrical would be easier to install, I'd imagine, because all you'd need to do is install a sending unit down on the tranny end, run your wire however/wherever you want the speedo to be, and then hook up that signal wire to the speedo along with your 12v switchable power, ground, and backlighting wires. They're also kinda nice for the fact that some will allow you to calibrate the speedo to correct for gears and tire sizes n' such. Biggest drawback is that they usually cost quite a bit.
Mechanical speedos are simpler in design and, theoretically, more reliable in that you don't have a sending unit that could possibly fail somewhere down the road. The pain, however, is fitting it to your stock speedo cable, or maybe to a universal cable, and putting that exactly into a spot where you like it. Plus, cable-driven speedos have issues (such as with OEM speedos) with the cable going dry or somehow otherwise causing the infamous bouncing needle symptom.
gcwh02
515
pottstown, PA
Sep 22, 2007
  • Sep 22, 2007
how hard is it to run the electrical one to your tranny?
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 22, 2007
  • Sep 22, 2007
Again, you'd just need to run some wire from a sending unit that either piggybacks onto or goes on just after the VSS (Vehicle Speed Sensor) on the tranny up to the speedometer.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
C
Resolved Dead speedometer... not odometer gears or trans speed sensor 4R70 W
  • cobramoneypit
  • Jul 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 22, 2026
cobramoneypit
C
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
