my stock throttle body is 70mm. is there any advantage to buying to buying a aftermarket throttle body of the same size? i just have some minor bolt on mods so i dont think i need anything bigger than 70mm.
Your stock throttle body is 60mm if you have a 94-95 5.0. There is an advantage to upgrading, however, if you have a few minor bolt ons you probably don't need it.
Sorry to hijack, but it should help the original poster... Would anyone like to chime in with their opinion on which aftermarket 70 or 75mm throttle body will flow the best? Has anyone done research to prove one brand better than others?
I haven't found any articles describing a direct TB comparison test so I can't answer the question directly. I do have a Summit Racing 75mm TB which is a very nice piece, and I ported the upper intake manifold opening to match. Throttle response was much improved and I like it.
