air cleaner clearance
  • Thread starter Thread starter Buckhunter125@h
  • Start date Start date Jan 18, 2009
Buckhunter125@h
44
illinois
Jan 18, 2009
  • Jan 18, 2009
will a 302 block with a weiand stealth intake ,holley and air cleaner fit under the stock hood of a 68 Mustang FB ???
How many inches could you lower the engine with fabbed up motor mounts or does someone sell motor mounts for this ????
Is it necessary for motor mounts to have rubber in them or can they be solid ?????
JonK
276
Nashville (Smyrna), TN
Jan 18, 2009
  • Jan 18, 2009
Hi, I've got a '67 Coupe, practically same car, same engine bay and I've got a Weiand Stealth highrise 8020 with a Demon Jr. (same as holley), a 1/2" phenolic spacer and a drop base 14" air cleaner with 3" filter and still clear my turn signal hood. I think the last time I measure it was ~1/2"-1" of clearance with all that added. The drop base air cleaner is the key. I can measure with out the air cleaner to see what the clearance is from the top of the carb base but it'll be at the end of the week, traveling for work.
You could put some clay on top to see exactly, I just layed a telescoping pencil magnet next to the carb, closed the hood then measured how far it stuck up above the air cleaner.
Someone does make adjustable motor mounts, not cheap ~$200 I believe, check summit. You can use solid but I hope you don't have any fillings, and be sure you still use a rubber trans. mount or you'll crack the bellhousing I've read. Solid mounts are for racing, not fun on the street. Lakewood makes a good stiffer than rubber mount I've read, summit sells too.
You could always make a torque strap for the front of the motor if you want, that way you could take it off if you don't like it.
Jon
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Today at 2:12 PM
mattcrp1
M
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
