air conditioner help please...
I put a 5.0FI 5spd 93 GT engine in my 1970 Mustang with factory air - I replaced the condensor, expansion valve, dryer, lines, etc... It was charged with 134 freon and got cold but started popping the high pressure relief valve - lowered the pressure and stopped the popping but not cooling now. Now there is envirosafe freon in the system (runs appx same pressures as 134) and I can get it to cool a bit but not getting cold. I checked the pressure on the low side - compressor not running 85-90psi drops to 0psi in 5 seconds once it is running - it should be dropping to 40psi when the compressor kicks in - I have ran it like this for 50 miles at highway speed and nothing has changed - any ideas on what I can do to make it go cold. I have added another can of envirosafe and the pressure on the low side goes well over 100psi when the compressor is not turning and down to 0psi in 5 seconds when the compressor is turning - By the way the hot water diverter valve is working, the vacuum doors all work properly, the compressor is kicking on and the clutch is working fine etc...
How much freon is in the system? What does it call for(amount) What does the high side read when the system is on? Usually when the low side drops to 0 there is either not enough freon(which doesn't seem to be your case) or there is a blockage in the system causing the problem. Again, what does the high side read and how much freon is in the car?
normally when i do any ac work on a car and have the lines off before charging the system with r134a i would vacume the system down to negative 30psi or so..you dont want air in the system to start with.
I agree with the above ideas with a few more suggestions. I'm thinking there is a possibility that there is some cross contamination among the different refrigerants (and maybe system lubricants) you may have used. If so a system flush could be in order, then vacuum down the system and begin again with a clean start. If I read correctly you are still retaining the 70's style expansion valve as opposed to the late model Fox type orifice systems ? I am curious as to how well these two systems can mesh (we have a '67 coupe we need to do this to as well).
Thanks for the responses guys - I have 2.5 12oz cans of 134a in there now but no dice - same thing going on - I do not have a high pressure guage - just a low pressure one - it will max out the guage when the compressor is off and when I turn it on the guage will drop to 0psi in 5 seconds - I see we are all in agreement that there is some sort of blockage in the system - all new lines, new expansion valve, new dryer, new condensor, used compressor and original evaporator under the dash - at this point I think I will take your insight and go to a qualified a/c mechanic and have the system vacuumed down to -30lbs and have them add a cleaner to the system and see about clearing the lines of any blockages by blowing them out etc... and letting a professional charge the system once this is done - I just hate thinking about someone else working on my car.
Air conditioning FIXED now - I ended up taking it to a shop - they located the problem - the NEW expansion valve was defective and I got another one and a new dryer to boot - they flushed the system, vacuumed it and re-charged it with 24oz of 134 freon, proper system oil, etc... pressures are supposed to be 20psi low side at 85 degrees and 175-200psi high side at 85 degrees and car at idle. As far as the question about orfice tube style compressor being mixed with the expansion valve - they work fine - you have to use one or the other - I was told it was easier to stay with the expansion valve system and just make up the hoses to fit the newer 5.0 style (F6 I think is is called) compressor. Hope this helps someone else...
Glad you got your A/C fixed & thanks for the info. :nice:
