hey guys, I just experienced something interesting and would like some feedback. I was just doing some reg maintenence, changed the belt, put in a K&N filter, and threw the silencer for distance. I also cleaned the TB out with some brake cleaner.
When I started it up, I 1st noticed that the engine was slightly louder,
then I started noticing an intermitent thumping noise from the filter/rubber intake tract.
at the same time the filter would also slightly jump. does it most after i rev it a little as the revs drop, ocasionally at idle. seemed to lessen as it warmed up. the idle is stable, rev's freely. everything is hooked up correctly w/no leaks.
What could this be?? some kind of reversion? is it normal and just hearing it because i removed the silencer and changed filter? burnt valve?
It's a 2000gt 5spd with only 38k on it and i take good care of it. i drive it hard, but don't abuse it.
I have not driven it yet, don't know if I should worry about it or not.
Thnx all
at the same time the filter would also slightly jump. does it most after i rev it a little as the revs drop, ocasionally at idle. seemed to lessen as it warmed up. the idle is stable, rev's freely. everything is hooked up correctly w/no leaks.What could this be?? some kind of reversion? is it normal and just hearing it because i removed the silencer and changed filter? burnt valve?
Thnx all
