air / fuel guage question
  • Thread starter Thread starter fiveoho
  • Start date Start date Apr 7, 2006
fiveoho
1,958
TN
Apr 7, 2006
  • Apr 7, 2006
how hard is to hook up a air / fuel guage on a 95?
big deal or not too bad?
thanks
D
Daggar
3,902
  • Apr 7, 2006
It's a piece of cake but serves no real purpose other than some pretty lights unless combined with a wideband.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 7, 2006
  • Apr 7, 2006
Cash=wasted
fiveoho
1,958
TN
Apr 7, 2006
  • Apr 7, 2006
10 bucks doesnt seem much to waste to me
D
Daggar
3,902
  • Apr 7, 2006
That's 10 bux I'd rather put into the fuel tank. lol
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 7, 2006
  • Apr 7, 2006
Use 43 (Dark Blue/Lt Geen wire) or pin 29 (Dark Green/Pink wire ) on the computer. Use Wire tap-ins from Radio shack P/N 64-3052. The computer is located under the passenger side kick panel. That keeps you from having to crawl under the car and make a weather proof splice in the wiring. You can use either one, or run a SPDT switch and use both. Then you can use the switch to select which side to view.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/t...91eecPinout.gif
The A/F gauges that use the O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between .2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information except when the mixture is extremely lean or extremely rich, there is no middle ground.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
89Notch
1,669
MSU
Apr 7, 2006
  • Apr 7, 2006
If you don't think $10 is a waste you can send it to me and i'll tell you if you are rich or lean
fiveoho
1,958
TN
Apr 7, 2006
  • Apr 7, 2006
finally, a real answer. i appreciate it.
thanks
D
Daggar
3,902
  • Apr 7, 2006
HAHAHAHA.... is that like: "Sit on my face and I'll guess your weight!"? LOL
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 7, 2006
#10
  • Apr 7, 2006
  • #10
you can enjoy the light show..I wouldn't try to tune with it though.
L
luckythirteen13
648
Anaheim, CA
Apr 7, 2006
#11
  • Apr 7, 2006
  • #11
you cant tune a car with a narrow band o2 gauge. i have one in my car but its hooked to my lm-1 wide band o2 and gives me a reading from the wide band o2
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Mindseye007
  • Aug 16, 2026
Mindseye007
