Air/fuel ideas
  • Thread starter Thread starter NotchPower
  • Start date Start date Dec 8, 2007
N
NotchPower
18
Clifton, New Jersey
Dec 8, 2007
  • Dec 8, 2007
Hey guys just wondering what injectors, throttle body, and mass airflow meter i should use. I have a bolt on 306 if that helps.
9
90bluegt
592
  • Dec 8, 2007
Need more that, it's bolt on 306. That really doesn't say anything about the engine minus it's a 306.
What heads, cam size, intake, etc....
Also, what horse are you projecting to have???
white99gt
4,649
stockbridge,Ga(near atlanta)
Dec 8, 2007
  • Dec 8, 2007
Depends on the bolt ons..But 24lb injectors,65mm tbody, with a 90mm lmaf (but it will need a tune with this combo)..
N
NotchPower
18
Clifton, New Jersey
Dec 9, 2007
  • Dec 9, 2007
alright sorry heres what it has. It a 306 with Edelbrock performer upper and lower intake manifold, underdrive pulleys, b303 ford cam, headers to mac mufflers no cats, a/c and smog delete, cold air intake, stock e7 heads. thats basically it. thanks
jtfairlane
468
  • Dec 9, 2007
Your performer upper plenum has a 70mm throttly body opening, so keep your throttle body size in the 65-70mm range.
Based on your parts list, I wouldn't bother getting larger injectors, you're not making anywhere near enough power to need them. I'd stick with the stock 19lb/hr injectors.
If you expect that in the future that you would want to do something like a set of heads or forced induction, than upgrading the injectors and a matching MAF wouldn't be a terrible idea.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 9, 2007
  • Dec 9, 2007
If you are looking to do the cheap but works good thing, here's an idea to use with the stock injectors and stock tune...
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Fuel Fuel injector cleaner?
  • Creomod
  • May 29, 2026
Fox 5.0 Mustang Tech May 30, 2026
evintho
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
