  • 1994 - 1995 Specific Tech
air fuel ratio
  • Thread starter Thread starter db500hp
  • Start date Start date Mar 19, 2006
D
db500hp
midwest
Mar 19, 2006
  • Mar 19, 2006
hey whats up? need to know what the proper air fuel ratio is for a super charged application and a non super charged aplication. i would aloso like to know what the proper fuel pressure is for a super chargerd and non aplication. last is what is the differance between a wide banned or regular air fuel ratio monitor besides the price.
ProKiller
3,064
15
78
PA
Mar 20, 2006
  • Mar 20, 2006
12.8-13.2 at WOT for a n/a car
12 is a decent number for a supercharged car
40 psi is a good number for a fuel pressure.
a wide band is pretty much the same thing a dyno uses to measure your a/f ratio. gives you a read out in actual numbers. an autometer type one only gives you a generally idea. red=lean, green=rich...not too accurate.
D
db500hp
midwest
Mar 20, 2006
  • Mar 20, 2006
thaks for the info. it sounds like we have real similar mods. i have a dss 306 rolling assembly anderson b-31 cam no power pipe, everything els seems similar. is 40psi good with boost and n/a? what do you run your timming at?
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Mar 21, 2006
  • Mar 21, 2006
Im shooting for an 11.875 A/F at WOT, 14.6 at cruising and I am using the Zeitronix WB02.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 21, 2006
  • Mar 21, 2006
If by chance (heck, I believe you will ) you see a nasty lean spike when nailing the skinny pedal from cruise to wot .........
You can knock it down with the manifold scalar
Start off by reducing the value by one full point and ajdust to your satisfaction
Grady
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
