Airbag connector under dash
I know where the module is located on the passenger side for clearing codes. Isn't there also a connector under the dash on the drivers side. I am trying to fix a code 12 (low battery feed), the fuse keeps blowing. I want to look and see if the connectors need to be cleaned. Thanks in advance!
I believe the air bag module is inside the front console, where your radio is and stuff. If you fold back the carpet on the driver's side a few inches in front of the gas pedal, you should be able to see the connectors. Getting them disconnected is a whole 'nother story though.
Isn't the one he is looking for on the drivers side, under the hood, in front of the strut tower?
The connector under the drivers side of the dash is a OBDII plug and only functional on the V6 cars which had that version of eec.
Scott
Scott
There's a separate airbag clearing code plug, which sit just under the glove box. You can't use the diagnostic plug to clear airbag codes
Do a search under my name and I have a post that explains how to clear codes and the location of the code clearing plug.
