Yeah, but I'd do 90* increments to find the best place then do +/- 45* to find the best. You can also do the front to really get it dialed in. I put mine on jackstands and BLOCKED the front tires front and back. You'll need a 12pt 12mm socket for final torquing and I used a box end wrench with an extension bar to break them loose. You can torque them down by hand for the short testing session on the jackstands. Once you get it dialed in use blue locktite and torque them to spec. You may need a 12mm x 1.75 tap to clean up the unused holes, I did.
I ended up with a hose clamp on the pinion flange to offset my 0.002" of runout. My vibration is now liveable but not totally gone. I have two vibrations with my aluminum DS 52 MPH and 63 MPH. I want to find someone who can field balance the DS on the vehicle.
Good Luck, Don
