Alignment after offset rack bushings??
BLADDER92FOX
153
Miami
It wouldn't hurt to have it alignment. But the only thing that would change would be the toe. And you could check that your self with the help of a buddy. All you have to do is get a tape measure and measure from the center of the tire on the back side to the center of the other front tire on the back side, and then do the same thing on the front side. If its off you would just need to turn one of the inter tierods untill you get the same measurements on the front and back side.
I ordered the strut tower brace from MM cause i have to align one of the strut towers back to specs at a chasis shop before i aligned the car. I also ordered the bumsteer kit from MM for 87-93 rack with 94-95 spindles and tomorrow i'll go to the shop and buy the rack bushings all together. I'm tireed and bumpsteer and vibrating wheels up front when driving fast.
